Video Summary
The host introduces the Cyrusher Aura electric bike and explains why it has become his daily commuter as well as his preferred choice for rides, whether with family or solo. Throughout the video, he highlights real-world performance data — such as actual range compared to the advertised range — and details improvements made for safety and comfort. He concludes by demonstrating the torque sensor’s capabilities through demanding off-road tests, particularly on sand and steep slopes.
Key Highlights and Timestamps
[01:13] Real-world Range Test: Overview of the 52V / 15Ah (780Wh) battery equipped with Samsung cells. While Cyrusher claims a range of 95 km, the host covered 87.7 km on mixed terrain without fully draining the battery, confirming the realism of the advertised range.
[03:38] Installing an Anti-theft Alarm: Demonstration of a security alarm with a motion detector and remote control; it emits warning beeps followed by a loud siren if the tampering continues.
[04:46] Integrating a Folding Lock and U-lock: Showcase of a compact 1.2-meter folding lock mounted directly to the pre-drilled holes on the frame, complemented by an additional U-lock carried in the panniers.
[05:54] Motor and Torque Sensor vs. Cadence Sensor: Explanation of the 250W rear hub motor delivering 95Nm of torque. The host shows how to switch between standard cadence sensing and progressive torque sensing via the control display.
[08:59] Braking and “Fat” Tires: Overview of the Logan hydraulic disc brakes and the wide 26 x 4-inch fat tires, ensuring a smooth ride on all types of terrain.
[10:23] Customization with a Suspension Seatpost: To compensate for the lack of rear suspension, the host installed a specific suspension seatpost, protected by a cover, to improve ride comfort.
[12:06] Premium Panniers and Cargo Rack: Presentation of the optional kit including a robust rear rack and metal fenders, as well as a quick-release double pannier system and a trunk bag. [15:46] Frame Design and Integrated Lighting: Overview of the aluminum frame with internal cable routing, dual integrated rear lights in the frame, and a functional brake light.
[18:48] Cockpit and Upgraded Grips: Tour of the color LCD screen (easily readable in daylight), the ultra-sturdy smartphone mount, and the soft, customized ergonomic grips.
[23:17] Off-road Tests and Extreme Slopes: Practical real-world trials, including riding through deep, loose sand and starting from a standstill on extremely steep and slippery slopes, using different assist levels.
