https://cyrusher.fr/products/zenith
The video follows a relaxed electric-bike ride along the Vendée coast, from Saint-Gilles-Croix-de-Vie toward Les Sables-d’Olonne. The route passes fishing-port scenery, beaches, dunes, and pine forests, with stops to enjoy the view rather than chase a distance or speed record. The presenters particularly praise the cycle path through the Olonne forest.
The ride also serves as a test of the Cyrusher Zenith fat-tire e-bike. The host says electric assistance is useful on longer outings and for dealing with headwinds, gentle rises, and changing surfaces. The bike’s wide tires and front suspension make it feel stable on uneven paths, while its upright riding position and broad gel saddle are described as comfortable.
Bike Features and Test Notes
26-inch wheels with 4-inch-wide tires, an aluminum frame, and front suspension.
250 W motor, with assistance limited to 25 km/h, and a 780 Wh battery (52 V, 15 Ah).
The stated theoretical range is 96 km. The presenters rode about 50 km and reported roughly three of five battery indicators remaining. Actual range varies with assistance level, wind, terrain, load, and riding conditions.
Seven-speed Shimano gearing and five electric-assist levels.
The display shows information such as speed, distance, travel time, and battery level. The rear lights also illuminate when braking.
The battery can be removed for charging. The bike comes with assembly tools and accessories, including a luggage rack and mudguard.
Practical Tips
Take your time on a scenic route: stop, take detours, and enjoy the surroundings rather than focusing only on the remaining distance.
Adjust the assistance to the terrain and conditions; even a low setting may be enough on an easy route.
When assembling the bike, follow the instructions and inspect the parts before removing packaging or cable ties.
Keep the disc-brake spacer used for shipping, and remove it only when installing the wheel; otherwise, the brake pads can close together.
Check the pedal markings and threading directions before fitting the pedals.
