[00:00] Introduction: The reviewer introduces the Cyrusher Zenith, following up on a previous review of the Cyrusher Flex, highlighting its impressive size, bulky 4-inch fat tires on 26-inch wheels, and clean weld finishes.
[01:39] Design, Frame & Weight: Discusses the aluminum frame, color options (silver, green, dark grey/matte black), integrated bottle cage mounts, and the 34 kg total weight, which is reasonable for a heavy-duty fat bike.
[02:30] Motor, Battery & Charging: Details the 250W rear hub motor with 95 Nm of torque, the integrated 52V 15.5 Ah battery system with a quick-release mechanism, battery-level indicator, and the charging port located near the pedal assembly.
[03:50] Gears, Drivetrain & Riding Speeds: Covers the 10-speed Shimano Tourney derailleur and how the gear ratios make it easy to pedal beyond the legal 25 km/h motor assist limit.
[04:42] Saddle, Ergonomics & Height Adjustments: Reviews the comfortable seat, seatpost height adjustment marks, and sizing guidelines (suitable for riders from roughly 1.55m to 1.90m).
[05:41] On-Road Riding & Handling: The reviewer takes the bike out for a test ride, noting the smooth torque sensor response, stability over rough ground, and performance when descending.
[09:18] Brakes, Suspension & Components: Examines the Logan hydraulic disc brakes (180mm rotors), the semi-rigid frame design (relying on fat tires for rear shock absorption rather than a heavy rear suspension), the lockable front fork, high-end aluminum pedals, and the sturdy kickstand.
[10:52] Lighting & LCD Display: Highlights the powerful 4-LED front headlight, rear tail lights with a built-in brake light feature, and the bright, highly visible LCD display screen.
[12:30] Pricing & Final Verdict: Discusses current anniversary pricing (around €1,249 to €1,299 with promo codes), addresses minor setup tweaks (such as handlebar stem length preference), praises the natural pedal-assist feel and long battery range, and concludes that it is an exceptional value fat bike.
