Aura | How to remove speed restriction for private land use
Can anyone help me? How can I unlock Aura for use on private land? Is there a video tutorial? Thanks
You will need to access the controller located within the crank housing and below the battery..you should see a short white wire going into a short black wire and a black plug.. disconnect this plug and your bike should reach 28mph but will still be limited to 20mph on the throttle. (If you have one that is). If you do this, I would keep it in torque sensor mode to save battery. Good luck :crossed_fingers:
Thank you so much. It worked! :grinning_face:
