Brake pads are crucial for the safety of e-bikes. As the characteristics of brake pads wear down over time with prolonged riding, this post will share tips on when and how to replace them.
Materials
There are three main types of brake pads:
- Organic: Quiet and great initial bite, but wear faster
- Metallic: Longer-lasting and better in wet conditions, but noisier
- Semi-metallic: A balance between the two
Cyrusher model brake pads size:
You can check the specific brake pad size from this link:
Replacement Steps
1. Remove the wheel (usually not necessary for most e-bikes)
2. Locate and straighten the cotter pin
3. Remove the caliper mounting bolts
4. Slide out the old pads
5. Insert new pads
6. Reinsert the cotter pin and bend it back
7. Remount the caliper
8. Adjust as needed
Tips
- Don’t squeeze the brake lever with the pads removed
- Check pad thickness regularly - replace when less than 1.5mm
- If your brake pads are oily and have other contaminants attached, they need to be replaced promptly.
What brake pads are you all using on your e-bikes? Any favorites or ones to avoid? Share your experiences and help out fellow riders!
Remember, when in doubt, your local bike shop is always there to help. Stay safe and happy riding, everyone!
