Cyrusher Kommoda 3: An Almost Perfect e-bike Reviewed
https://www.cyrusher.com/products/kommoda-2-0
I. Summary of Key Pros and Cons
:+1: Pros
1.
Exceptional Range: Equipped with a massive 960Wh battery, it offers an official range of up to 68 miles (approx. 109 km); real-world testing shows it can last about a week of daily commuting and weekend riding before needing a recharge.
2.
Excellent Suspension System: Features air suspension (with robust stanchions and compression/rebound adjustment knobs) and rear shock absorption, performing impressively on bumpy dirt roads—a rarity among e-bikes in this class.
3.
Powerful Motor Output: Driven by a 750W rear hub motor, the bike delivers ample power, easily handling steep hills and complex, muddy terrain.
4.
Outstanding Braking Performance: The mechanical disc brakes provide strong stopping power, and the brake levers feature small adjustment screws that allow for tension tuning without tools.
5.
Superb Nighttime Lighting: Bright front and rear lights; notably, the taillight automatically brightens when braking, significantly enhancing safety for night commuting.
6.
Comfortable and Stable Tires: Equipped with extra-wide 20×4-inch tires that provide excellent traction and stability on uneven terrain.
👎 Cons
1.
Lacks Stock Cargo Features: Despite being marketed as a multi-purpose/cargo adventure bike, it does not come standard with a rear rack or cargo platform (accessories must be purchased separately), and the rear design makes it difficult to mount universal panniers.
2.
Inconvenient Display Settings: While the display screen is bright and clear, switching to kilometers (KM) is difficult (as it defaults to miles), and the mode-switching process is complex enough to require a careful read of the manual. 3.
Heavier Weight and Speed ​​Limits: The bike weighs 83 lbs (approx. 37.6 kg) and can reach speeds of nearly 30 mph as a Class 3 e-bike; in some areas, this may exceed local regulations for roads or bike lanes.
II. Summary by Time Segment
[00:00:00 - 00:02:10] Model Introduction, Range, and Suspension Performance
Introduces the model (Cyrusher Kommoda 3), positioned as a high-performance outdoor adventure e-bike.
Highlights the massive 960Wh battery and long range, and details the high-performance rear suspension system featuring compression and rebound adjustments as well as air-shock capabilities.
[00:02:10 - 00:04:19] Power, Braking, and Lighting Systems
Analyzes the robust power delivered by the 750W motor and notes its dual-mode capability (Class 2 and Class 3, reaching up to 30 mph—subject to local regulations).
Demonstrates the powerful mechanical disc brakes and the ultra-bright front and rear lighting system, which includes a high-visibility brake light function.
[00:04:19 - 00:06:01] Drivetrain, Riding Modes, and Handling Adjustments
Introduces the 7-speed Shimano drivetrain and the two pedal-assist modes: “Touring” and “Sport.”
Highlights features such as easy-adjust brake screws on the handlebars, adjustable handlebar height, fenders, and 4-inch wide tires that ensure riding stability.
[00:06:01 - 00:08:04] Drawbacks, Price, and Conclusion
Points out two downsides: the lack of a factory-installed cargo rack (requiring the purchase of a metal accessory rack) and the cumbersome process for switching display units (stuck in kilometers mode). To summarize its overall performance: the official price is around $2,000, while the frequently available discounted price is approximately $1,599. The reviewer personally likes it so much that they have decided to keep it, considering it an excellent choice for both off-road adventures and daily commuting.
