Cyrusher Kommoda Pro - FULL REVIEW!
This video is from the Karl Vaughan channel and features a detailed unboxing, real-world test, and comprehensive review of the Cyrusher Kommoda Pro—an e-bike dubbed the “SUV of the e-bike world” [00:22].
I. Video Summary
The creator tests the Cyrusher Kommoda Pro’s key hardware specifications, including the 52V 20Ah battery, 250W motor, 85 Nm of torque, 20x4-inch fat tires, full suspension system, and torque sensor [00:36]. The video covers night-time lighting tests, seat post and battery removal/adjustment, and tests for unpowered riding and walk-assist modes. It also includes multi-terrain field tests across hills, woodland trails, country roads, and canal paths [06:29].
II. Pros and Cons Analysis
Pros
Powerful off-road and suspension performance: The combination of full suspension and 20x4-inch fat tires effectively absorbs shocks from gravel, branches, and potholes, ensuring a comfortable ride on forest trails and unpaved surfaces [09:48].
Natural power and pedal assist: Equipped with a torque sensor, the pedal assist delivers smooth, natural power; the bike also offers a decent riding experience even without power, thanks to its ability to maintain momentum [00:46].
Comprehensive lighting and safety features: The headlight is extremely bright (offering excellent night visibility), and the taillight integrates turn signal and brake light functions, enhancing safety for night riding [01:01].
Convenient battery removal: Comes with a key; simply turn it clockwise to easily unlock and remove the battery [04:15].
High adjustability and versatility: The handlebar angle is adjustable, and the rear rack supports a load of up to 25kg. While the stock configuration fits riders up to 6’3" (approx. 190cm), taller users (like the 6’6" host) can easily achieve a proper fit by simply swapping in a longer seat post [00:54]. Cons
Heavy weight: With a curb weight of 39 kg, lifting the bike over curbs or bringing it indoors is physically demanding [05:06].
Subpar handlebar grip comfort: The grips have deep texturing and a hard texture, which can cause palm soreness or chafing during long rides (replacing them yourself is recommended) [18:05].
Noticeable noise and stuttering under heavy load: When using high-assist mode (PAS 5) on steep slopes, the motor is loud, and there is an occasional, inconsistent “jerking” or “surging” sensation [08:08].
Inadequate manual: The advanced settings menu on the display lacks official documentation; the manual does not detail the meaning of specific parameters, making it difficult for users to adjust settings [18:37].
Walk mode cannot replace a throttle: The “Walk Mode” (activated by holding the minus button) only maintains a walking speed of about 3.6–4 mph and cannot be used to ride the bike (with or without a passenger) like a pure throttle system [05:23].
III. Video Timeline Summary
Exterior Specifications and Hardware Overview
00:00:00
Introduction to the Cyrusher Kommoda Pro’s key specifications (52V 20Ah battery, 250W/85Nm motor, hydraulic disc brakes, Shimano 7-speed drivetrain, turn signals, rear rack, etc.) [00:36].
Nighttime Lighting Test
00:02:03
Testing the headlight and taillight on a dark road without streetlights; the headlight offers a wide illumination range, and the taillight and brake light are highly visible [02:23].
Rider Height Compatibility and Seatpost Modification
00:03:03
Addressing the issue of the stock seatpost being too short for tall riders (198cm) by demonstrating how to replace it with a longer seatpost to accommodate taller users [03:35]. Battery Removal and Functional Testing
00:04:15
Demonstrating the battery removal and installation process, and testing the bike’s performance in unpowered (manual) mode and “Walk Function” mode [04:44].
Steep Hill Climb Test (Aston Hill)
00:06:50
Tackling a steep incline with maximum assist to evaluate motor power output, noise levels during climbing, and the smoothness of power delivery [07:04].
Woodland Trail and Fat Tire Experience
00:09:43
Riding on forest trails to test how the full-suspension system and wide tires handle branches, loose gravel, and bumpy terrain [10:12].
Country Roads and High-Speed ​​Descents
00:11:19
Cruising on country roads and evaluating handling and stability during high-speed descents [13:27].
Canal Path Riding
00:15:44
Testing maneuverability and the ability to handle challenging surfaces (such as mud and obstacles) on narrow canal paths [16:04].
Summary and Pros & Cons
00:17:30
Summarizing the overall riding experience, highlighting drawbacks—such as stiff handlebar grips, heavy weight, and a missing manual—and offering purchasing advice [18:05].
