CYRUSHER KOMMODA PRO: Testing this unique electric bike! #motorhome, #vanlife
[00:05] – Presentation and introduction
General overview of the Cyrusher Kommoda Pro electric all-terrain bike (green model), tested in an outdoor setting.
[00:38] – Unboxing and assembly
Guide to the parts requiring assembly upon delivery: installing the front wheel, handlebars, headlight, mudguard, and pedals, as well as adjusting the stem.
[01:48] – Technical specifications and equipment
Detailed breakdown of components and features:
Battery: Removable 52V / 20Ah battery (6–7 hour charge time) with a claimed range of up to 110 km.
Equipment: LCD display, adjustable front and rear suspension, rear rack (25 kg max load), LED lights with brake light function, and non-slip grips.
Weight & Motor: Weight of 39 kg; 250W motor delivering 85 Nm of torque.
[04:30] – Trail and road test (Real-world testing)
Without assistance: Initial handling test to evaluate manual pedaling.
With assistance (levels 1–5): Testing on dirt paths and gentle inclines. Highlights the efficiency of the torque sensor and the comfort provided by the dual suspension when handling obstacles and bumps.
Speed: Consistent maintenance of the capped speed of 25 km/h.
[12:10] – Walk mode and braking test
Demonstration of walk mode (5 km/h assist) for effortless pushing up hills, as well as the 180mm hydraulic disc brake system.
[14:18] – Summary and conclusion
Pros: Excellent saddle comfort, effective suspension, easy hill starts, and impressive range. Weakness: The weight (39 kg), which can make transporting it on a bike rack more challenging.
