The motor, as one of the most significant components of an electric bicycle, must be maintained for the vehicle to operate more effectively and to ride effortlessly in challenging mountain areas. This article will show you how to maintain an ebike motor.
- Keep the motor away from water and moisture
Keep the motor as far away from water and humidity as possible. Although some ebikes are water-resistant, it is still recommended that the bike not be exposed to excessive moisture for extended periods of time. This is because once the motor has been exposed to water, the damage to its performance is irreversible, making the subsequent repair process harder.
- Avoid overheating the motor
As we all know, summer is the most preferred season for e-bike riding. The wonderful weather naturally creates enthusiasm for sports. Summer riding, on the other hand, is inevitably followed by the issue of high motor temperatures. External environmental conditions, together with the self-heating temperature generated by the motor over time, might cause the motor to become excessively hot and, hence, degrade its performance.
In order to promote motor protection, motors, in general, include automated protection settings that will immediately turn off the power and stop the motor running in case of excessive temperatures. You may remove the components around the motor to assist in the release of heat quicker if you want to cool it down faster.
- Avoid unhealthy use of the motor
Many riders use their e-bikes for tough mountain riding to experience the exhilaration of climbing hills. However, this sometimes results in irrational use of the motor. When encountering a very high gradient, for example, driving the motor in constant high-speed mode causes the gears to wear out too quickly which can trigger the generator controller’s cooling protection. Often, the cooling protection reduces the motor’s horsepower compared to before as heat damages the motor’s efficiency.
- Keep the motor and area clean
Failure to clean and maintain the motor may also have an adverse effect on performance. Fat-tyre e-bikes provide the user with additional riding options and allow the vehicle to explore more diverse riding terrains. When riding on unpaved roads, mud, sand and other debris are bound to get into the vehicle’s chain gears and other places that are often overlooked when it comes to cleaning. The residue of dirt can harm many components of the e-bike, including the motor, during the long-term oxidation process for most models with rear-mounted hub motors.
- Store the motor properly
The motor’s storage location is also a significant maintenance consideration. Properly storing the motor will help to protect its performance. External temperatures, whether hot or cold, might have an impact on the engine’s performance. Keeping the vehicle in a cool and dry area is advisable to guarantee safe and adequate storage conditions.
- Contact the manufacturer if there is a problem with the motor
The ebike motor is covered by warranty, contact the manufacturer timely if there is a problem with the motor
Summing up
The motor is an essential component for powering the vehicle. When purchasing, choose the motor specifications that best meet your demands to avoid over or under performance. The efficacy of the motor can be damaged if it is used in a way that is not recommended. Attention should be paid to riding and storing it properly. Ongoing maintenance can boost the power and durability of your e-bike, allowing you to get the most out of it for years to come.
