The adventure continues with Cyrusher,
After the Kommoda 3.0 in 2025, this year it’s the purchase of the Aura; this bike is absolutely mind-blowing, except for the comfort of the saddle. As for the cadence sensor, there’s no need for pressure on the pedals, just the weight of the foot and the movement, and the Aura reacts instantly. The motor and torque are no slacks—in assistance 1 and first gear, it handles everything: cruising, off-roading, acceleration, and pickup; it’s impressive, and derestricting it is unnecessary. And regarding range, after 48km, only one battery bar was lost. The cadence sensor is super responsive and sensitive; once the desired speed is reached, you just have to keep the pedals turning without exerting force; if you want to go faster, a slight pressure on the pedals reaches the desired rhythm again, all while in assistance 1. I find the look of this bike simply magnificent; with its overlapping bar and its 26/4" tires, it gives it a beastly look. The display is bright, and I think it’s one of Cyrusher’s nicest; the lights are integrated into the frame, and the riding position is very pleasant and comfortable, except for the saddle—Cyrusher, you should use the same saddle as the Kommoda 3.0—and the braking is powerful.
To conclude, the Aura is a bike of mind-blowing quality that looks badass…
Thanks Cyrusher!
