Is this electric bike going to stay in my garage?! Cyrusher Zenith - Black Friday
https://cyrusher.fr/products/zenith
In this video (HKTROTT: Ce vélo électrique va-t-il rester dans mon garage ?! Cyrusher zenith - black friday), the creator unboxes, presents, and tests the Cyrusher Zenith electric bike on the road, off-road, and in the rain to decide whether it deserves a permanent spot in his garage.
Unboxing & Initial Setup
Packaging & Aesthetics: The bike arrives well-packaged [02:16], and the presenter highlights its striking green color [02:43], which shifts slightly toward blue in bright sunlight [21:24].
Accessories: The brand sent an extra rear rack/basket accessory that doubles as a rear fender [05:44]. While he installs the rear rack and fender for practicality, he leaves the front fender off because he prefers the bike’s clean, stripped-down look [06:00].
Assembly Tip: He advises thoroughly tightening all bolts before riding, noting that his handlebar stem had noticeable play during braking until he tightened it properly [12:50].
Key Specifications & Features
Tires & Weight: Features oversized 26 x 4-inch fat tires [10:09] and weighs 33.8 kg [10:54].
Battery & Charging: Equipped with a removable 52V 15Ah battery [09:10] that can be charged either on the bike or indoors separately [09:47], taking roughly 6 to 8 hours with the included 2A charger [10:23].
Water Resistance: Rated IPX5 for the bike frame and IPX6 for the electrical components [10:41].
Brakes & Drivetrain: Uses Logan hydraulic brakes (similar to those on Nami electric scooters) [11:00], a Shimano drivetrain [12:28], front suspension forks [12:32], and 9 pedal-assist levels [11:29].
Smart Features: Includes an automatic lighting system that turns the front and rear lights on or off based on ambient sunlight [25:11], as well as a switchable torque sensor mode for more responsive acceleration on climbs [24:04].
Road, Rain & Off-Road Testing
Speed & Acceleration: Out of the box, the bike is street-legal and capped at 25 km/h [09:05], reaching that speed quickly [16:07]. He briefly unlocks the speed limiter in an industrial zone to test top speed before re-limiting it for public paths [14:02].
Wet Weather & Off-Road Handling: Tested in heavy rain, mud, and wet leaves [18:58], the bike maintains strong grip and stability without slipping [30:10].
Battery Endurance: After riding roughly 30 km across his tests—starting without a full charge—the battery only dropped by a single bar [29:56].
Pros, Cons & Final Verdict
Pros: Attractive design, great battery efficiency, reliable wet-weather traction, responsive torque sensor mode, and practical rear rack utility [29:50].
Cons: No dedicated rear suspension (only small springs under the saddle), which makes bumpy off-road rides harder on the rider [31:15]. The hydraulic brake pads also require a break-in period to reach full stopping bite [21:50].
Verdict: Yes, he decides to keep the Cyrusher Zenith in his garage as his personal all-around bike for both fair-weather cruising and rainy days [29:15].
