| Models | Kommoda | Kommoda 2.0 | Kommoda 3.0 | Kommoda pro |
| Range | 34miles range(55km) | 68miles range(110km) | 68miles range(110km) | 68miles range(110km) |
| Motor | 480V 250W(EU version) | 48V 750W | 48V 750W | 48V 750W |
| Battery | 48V 14ah | 48V 20ah | 48V 20ah | 52V 20ah |
| Charger | 48V 2.0A (charging time 6-7h) | 48V 3.0A(charging time 6-7h) | 48V 3.0A(charging time 6-7h) | 52V 3.0A(charging time 6-7h) |
| Suspension | Front: Oil &Spring Suspension fork with adjustment Rear: Spring suspension 165x750 lbs |
Front: Oil &Spring Suspension fork with adjustment Rear: Air Shock 165x750 lbs | Front: Oil &Spring Suspension fork with adjustment Rear: Air Shock 165x750 lbs |
Front: Oil &Spring Suspension fork with adjustment Rear: DNM 185mm air shock absorber with 50mm stroke |
| Frame | 6061 Aluminum Alloy with Internal Battery | 6061 Aluminum Alloy with Internal Battery | 6061Aluminum Alloy with Internal Battery | 6061 Aluminum Alloy with Internal Battery |
| Brake | Fully Hydraulic Disc Brakes 180mm Front + Rear | Fully Hydraulic Disc Brakes 180mm Front + Rear | Fully Hydraulic Disc Brakes 180mm Front + Rear | Fully Hydraulic Disc Brakes 180mm Front + Rear |
| Speed Sensor | Cadence sensors | Torque sensors | Torque sensors | Torque sensors |
| Shift Gears | Shimano 7-speed | Shimano 7-speed | Shimano 7-speed | Shimano 8-speed |
| Tire | Chaoyang 20 X 4 Puncture-Resistant Fat Tires | Chaoyang 20 X 4 Puncture-Resistant Fat Tires | Arisun 20 X 4 Fat Tires | Chaoyang 20 X 4 Puncture-Resistant Fat Tires |
| Seat post | 31.9mm /Adjustable height | 33.9mm /Adjustable height | 33.9mm /Adjustable height | 33.9mm /Adjustable height |
| Tail Light | Yes (Main battery powered) | Yes (Main battery powered) | Yes (Main battery powered) | Yes (Main battery powered) |
| Roads Condtions | City street, park,road | city street, park, road | city street, park, road | city street, park, road,trails, off road |
| Color | Orange, white, blue and gray | Green, Orange,Gray | Orange, Gray, Green | Yellow, Green, White |
| Bike Weight | 70.32lbs(31.9 KG) With Battery | 83.11 lbs (37.7kg) | 83.11 lbs (37.7kg) | 85.98 lbs (39kg) |
| Rider Height | 5’1 ~ 5’9 (155cm ~ 180cm) | 5’1 ~ 5’9 (155cm ~ 180cm) | 4’9 ~ 6’3 (150cm ~ 195cm) | 5’1 ~ 6’3 (155cm ~ 195cm) |
| Recommendation for | Riders looking for a compact, reliable, and budget-friendly e-bike with moderate range, ideal for city commutes or short leisure rides. | Those who enjoy longer commutes and want enhanced range compared to the original Kommoda. Great for urban or suburban trips without frequent recharging. | Ideal for city riders seeking comfort, long-range capability, quieter operation, and a better fit for smaller riders. | Ideal for those seeking a powerful e-bike with long range, it supports easy climbs with minimal charging. |
Kommoda 2.0 Upgrades
- Air Suspension Upgrade
- Rear shock upgraded to air suspension, offering smoother rides and better adaptability to varying terrains. Enhanced comfort for urban commutes and bumpy roads.
- High-Capacity Battery
- 48V 20Ah battery extends range to 68 miles (110km), ideal for longer commutes. Combines with the 750W motor to maintain power efficiency, even on slopes.
- Advanced Lighting System
- Front light upgraded to 1,000 max lumens for superior visibility in low-light conditions, improving safety during night rides.
- Frame Optimization
- Redesigned frame structure improves weight distribution and ergonomics, ensuring a balanced and fatigue-free riding posture.
- Torque Sensor Integration
- Replaces cadence sensor with torque sensor for intuitive power delivery. Responds dynamically to pedaling force, enhancing control and efficiency.
Kommoda 3.0 Upgrades
- Optimized Headlight Mount
- Adjustable headlight bracket with improved rotation angles prevents frame scratches and ensures consistent beam alignment.
- Quiet City Tires
- Arisun 20" x 4" urban tires reduce noise at high speeds and improve grip on paved roads, prioritizing comfort for city exploration.
- Rear Suspension with Bearing Design
- Bearings added to rear air shock for smoother compression and rebound, minimizing vibrations on uneven surfaces.
- Low-Profile Frame
- Lower frame height accommodates riders from 4’9" to 6’3" (150cm–195cm), particularly benefiting shorter riders with easier mounting and dismounting.
- Wider Frame Geometry
- Expanded frame span enhances stability and legroom, reducing strain during extended rides.
Kommoda Pro Upgrades
- High-Voltage Battery & Motor
- 52V 20Ah battery paired with a robust motor delivers higher torque for steep climbs and off-road trails, maintaining a 68-mile (110km) range.
- Puncture-Resistant Tires
- Chaoyang fat tires with reinforced layers withstand rough terrains (e.g., gravel, trails) while retaining urban compatibility.
- Shimano 8-Speed Drivetrain
- Wider gear range supports diverse riding styles, from high-speed urban commutes to controlled off-road ascents.
- Premium Motor Upgrade
- High-performance motor ensures consistent power output, excelling in both acceleration and sustained climbs.
- 2-Piston Hydraulic Brakes
- Star Union dual-piston brakes provide stronger stopping power and heat dissipation, critical for downhill or high-speed scenarios.
- Long-Travel Rear Suspension
- DNM 185mm air shock with 50mm stroke absorbs larger impacts, ideal for aggressive trail riding or uneven urban roads.
Performance Summary
- Range & Power: All upgraded models (2.0, 3.0, Pro) share a 68-mile range, but the Pro’s 52V system and motor enhancements prioritize raw power.
- Comfort: 3.0 focuses on ergonomic adjustments for diverse rider heights, while Pro emphasizes terrain adaptability.
- Safety: Pro’s brakes and tires offer premium off-road protection, whereas 2.0/3.0 optimize urban safety via lighting and quiet tires.
- Versatility: Pro’s 8-speed drivetrain and suspension make it a hybrid for city-to-trail transitions, while 2.0/3.0 remain urban-centric.
