Remove or unlock speed restriction
Share 2 links to videos about unplug speed limits that someone else uploaded:
  1. https://vimeo.com/user226327628
  2. https://www.youtube.com/@Ebikespeed-xw6tr/videos
On most cyrusher bikes…notably the ranger/rover, you have to access the control panel located within the pedal/crank housing and look for a short white wire plugged into another short black wire, pull apart or disconnect and bingo your bike should kow be capable of at least 28mph…happy and safe riding people always!
Although if your is bike throttle enabled it may only go to 20mph on the throttle…depending on model and age of your bike once successfully unrestricted…again, be safe peeps!
Hi, does derestricting the bike reduce the battery or motor life?
Unlocking or removing the speed limiter will of course reduce range and battery life but the motor should be fine.
Hi, is this the same for the Zenith? I’ve searched online but cant find anyone that has derestricted the zenith.
Still cannot find how-to…
https://youtu.be/OwwuEIF7Mp8?is=bTfgQIKJFBG2cqje
