Rumble vs Rumble 2.0
Feature Rumble Rumble 2.0
Range 58 miles (94km) 58 miles (94km)
Motor 48V 250W (EU version) 48V 250W (EU version)
Battery 48V 18Ah 48V 18Ah (with new base/handle)
Controller At battery bottom, old connector Inside frame, secure waterproof connector
Suspension Oil & Spring, adjustable Oil & Spring, adjustable
Frame 6061 Aluminum Alloy 6061 Aluminum Alloy
Brake Hydraulic Disc, 180mm Hydraulic Disc, 180mm
Shift Gears Shimano 7-speed Shimano 7-speed
Tires 20 x 4 puncture-resistant 20 x 4 puncture-resistant
Headlight 50 Lux LED 50 Lux LED
Color Options White, Black Blue, Gray, Green
Bike Weight 70.32 lbs (31.9 kg) 70.32 lbs (31.9 kg)
Rider Height 5’7 - 6’6 (155cm - 190cm) 5’7 - 6’6 (155cm - 190cm)
  • Controller Upgrade
The controller is now housed inside the frame, making it much easier to access and service compared to the old model where it was placed at the bottom of the battery. The connector is upgraded to a more secure, lightly waterproof design, offering better protection.
  • Battery Improvements
A new battery base and ergonomic handle make removing and carrying the battery much simpler and more comfortable.
  • Enhanced Front Bar Handle Lock
The front bar handle lock has been refined for smoother, more reliable operation, making folding and securing your bike easier and safer during transport or storage.
  • More Vibrant Color Choices
Step out in style with fresh color options like blue, green, and gray, alongside classic black. These new shades let you personalize your ride.
  • Upgraded Frame Design
The frame is redesigned with improved structural stability and a unified aesthetic, especially in the rear section where the frame and rack are now integrated. This design allows for seamless attachment of accessories like storage baskets or bags—perfect for commuting, errands, or adventure rides.
