Cyrusher: 5‑Step Summer Ride Checklist
Summer Heat Impact Tips
1. Battery Discipline
- Charge between 40%–80% to reduce stress in high temps
- Unplug once full to prevent heat damage
- Avoid full charge/discharge cycles during extreme heat
2. Heat Protection
- Store your e‑bike in the shade or indoors (under 77°F preferred)
- Don’t leave it in direct sun—even short exposure hurts long‑term performance
3. Drivetrain & Chain Care
- Clean + lube your chain weekly, or after dusty rides
- Use a bike-specific degreaser and wipe off excess lube
- Check for chain stretch—replace early to protect gears
4. Brake Maintenance
- Inspect pads monthly; heat makes them wear faster
- Clean rotors with isopropyl alcohol—no oils or solvents
- Check for “spongy” braking—may need adjusting or bleeding
5. Tire Checks & PSI
- Recheck PSI weekly—air expands in summer heat
- Inspect tread and sidewalls for wear or cracks
- Carry a patch kit and mini-pump on all hot-weather rides
Weekly/Monthly Maintenance Table
| Task | Weekly | Monthly |
| Battery Charge (40–80%) | ||
| Chain Clean & Lubrication | ||
| Tire Pressure & Visual Check | ||
| Brake Pad & Rotor Inspection | ||
| Heat Exposure & Storage |
Quick Tips
- A little care every week prevents major issues later
- Heat impacts every part: battery, brakes, tires—stay proactive
- Keep the checklist somewhere visible—toolbox, garage wall, or email folder
